Re: Re: 1466 with hydraulic problem
Posted by Mario on January 12, 2004 at 19:16:19 from (170.76.45.205):
In Reply to: Re: 1466 with hydraulic problem posted by Aces on January 12, 2004 at 04:52:58:
Thank You Ace for writing back. Today I took the plug off and the little piston that goes inside. I cleaned real good and placed in back. I admit that the o-ring on the outside seem to be a little worn but I didn't replaced it because the dealership was closed. Anyway, after placing it all back the hydraulic system starting working great, but after lowering and lifting it a couple of times with excitment it started doing the same thing. I am thinking that if I replace the o-rings the problem might be solved. Once again I thank you.
Post A Followup
: Re: Re: Re: 1466 with hydraulic problem
