Re: Re: Working with IH 2150 paint
Posted by lee on January 15, 2004 at 13:54:56 from (24.24.92.235):
In Reply to: Re: Working with IH 2150 paint posted by Geoff NY on January 15, 2004 at 08:03:10:
The can of 2150 I have says Alkyd resin which makes it an alkyd enamel. You can thin alkyd enamel with straight enamel reducer, paint thinner or naptha. Pretty sure you can even use acrylic enamel reducer to thin an alkyd but you must use acrylic enamel reducer with an acrylic. Straight enamel reducer, paint thinner or naptha will not work with acrylic enamel. Most any automotive paint store can set you up with a hardener for the 2150. Nothing real special about the IH on the can of 2150 other than the color. Not sure if an automotive store can come up with the same color for you. They might get close. The best way to thin paint for spraying is to get a viscosity cup at an automotive paint store. The cup is like a small dipper with a hole in the bottom. Dip the cup in the paint and pull it out. The paint runs out the bottom. Generally you'll want to thin it til you are in the range 18 to 21 seconds to empty the cup. You can control the viscosity very accurately with this cheap and simple cup. Test spray til you work out gun settings (atomizing air, paint supply, gun pressure that work for you). Record these settings and viscosity and you can get back to spraying in short order. With practice you will learn to adjust the gun for varying conditions. Spraying takes a little practice and is a bit of an art. You want a wet coat with no runs. Practice, practice, practice.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
