Re: Working with IH 2150 paint
Posted by CNKS on January 15, 2004 at 19:03:16 from (207.178.96.212):
In Reply to: Working with IH 2150 paint posted by Steve W (NY) on January 15, 2004 at 06:58:50:
Not going to argue with any posts below, but if you use hardener, put it in all coats, or the coats below may lift. DO NOT use hardener without a supplied air system, sooner or later it will get you. A charcoal mask is not sufficient. If you use quality paint such as that by PPG or DuPont, the spec sheets tell you exactly how mix it, you do not have to worry about viscosity. Do not deviate from these specs until you have had experience. As a beginner, get an HVLP gun, the only disadvantage to HVLP is that many experienced painters feel it is too slow. You won't notice the difference, you will use less paint and get a better finish.
Post A Followup
: Re: Re: Working with IH 2150 paint
