farmall 300 -6 or 12 volt
Posted by abane on January 15, 2004 at 19:30:53 from (4.37.74.211):
I went to look at a 300 Farmall and the person that had the tractor was using a 12 volt battery to try starting it.Are they 6 or 12 volt and are they positive or negative ground.I have a 350 amd a 400 farmall and the 400 is negative ground , 12 volt and the 350 is positive ground, 12 volt and both are original.How can you tell if it is 6 or 12 volt?
Post A Followup
: Re: farmall 300 -6 or 12 volt
