Re: Re: Jump Starting 6 volt with 12 volts
Posted by DaveinKY on January 16, 2004 at 16:15:30 from (64.136.27.227):
In Reply to: Re: Jump Starting 6 volt with 12 volts posted by lee on January 16, 2004 at 12:27:51:
I'm with the "cubber". If you remember the principal of positive (+) to positive (+) and neg to neg (-) and connect postive from 12V to the starter post and touch the negative from the 12V to the frame of the 6V tractor, you are only running 12V through the starter and not the battery or charging system. Hold it only long enough for a few revolutions then check to see why it hasn't started (forgot to turn the gas on?). Don't overheat the starter and you can do this without a headache. Have a happy winter!
Post A Followup
: Re: Re: Re: Jump Starting 6 volt with 12 volts
