Re: Re: Re: Jump Starting 6 volt with 12 volts
Posted by lee on January 16, 2004 at 20:49:22 from (24.24.92.235):
In Reply to: Re: Re: Jump Starting 6 volt with 12 volts posted by DaveinKY on January 16, 2004 at 16:15:30:
This will work if it has a separate starting solenoid but if it is an old starter with a mechanical starting switch mounted on the starter the starter post goes direct to the battery. You can crank a 6 volt starter with a 12 volt battery as long as you don't crank too long but make sure the 6 volt battery is not in the circuit.
Post A Followup
: Re: Re: Re: Re: Jump Starting 6 volt with 12 volts
