Re: 53 SUPER M BELLY PUMP
Posted by NDS on January 16, 2004 at 17:00:38 from (205.188.209.82):
In Reply to: 53 SUPER M BELLY PUMP posted by KEN on January 16, 2004 at 15:49:53:
I have pump out of SM SN F21257J and went out and checked numbers. I pulled this pump out of early M several years ago and has worked fine. Pump number is 5028E and casting code looks like 8 2 K. Have another pump that I think came out of SM (not sure though) and it is 5027E could not find casting code top of the pumps look identical to me. M could have had SM pump and casting code is X but I wire brushed it and it sure looks like K.
Post A Followup
: Re: Re: 53 SUPER M BELLY PUMP
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
