Re: Re: 53 SUPER M BELLY PUMP
Posted by KEN on January 16, 2004 at 17:53:07 from (205.246.142.87):
In Reply to: Re: 53 SUPER M BELLY PUMP posted by NDS on January 16, 2004 at 17:00:38:
THANKS ACCORDING TO MY SOURCES, THE SERIAL # YOU GAVE IS A "53" SUPER M RIGHT?? THIS OTHER PUMP YOU MENTIONED WITH #'S 5027-E YOU THINK CAME OUT OF A SUPER M, IS THE SAME AS THE ONE THAT WOULDN'T FIT UP IN MINE. YOU MENTIONED A CASTING CODE OF POSSIBLE X OR K , IS THAT BEHIND THE 5027-E CASTING #?? WE'LL FIGURE OUT THIS PROBLEM YET!!!!!!!!!!
THANKS
LATER
KEN
Post A Followup
: Re: Re: Re: 53 SUPER M BELLY PUMP
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
