Re: farmall m brake job
Posted by SGT K on January 18, 2004 at 12:39:28 from (65.120.161.29):
In Reply to: farmall m brake job posted by ih4fun on January 18, 2004 at 10:53:27:
IT sounds like you are trying to pull the bull pinion assembly, which contains the seal. STOP The inner roller bearing flange will break off when it contacts the bull gear. I just went through the bull pinion assemblies on an H and some of the guys gave me a lot of good advice. Look under the posts titled END PLAY or END PLAY DISCOVERED. If you need something more post again. People are always eager to help, and I will share what little I know.
SGT K
Post A Followup
: Re: Re: farmall m brake job
