Re: can a farmall A push snow
Posted by TimV on January 18, 2004 at 21:21:18 from (24.59.247.222):
In Reply to: can a farmall A push snow posted by David Arnett on January 18, 2004 at 10:58:36:
David: As the others have commented, the A will do a respectable job of plowing snow. The limiting factor is not so much power as weight and traction. Chains are nearly indispensable, and wheel weights or a drawbar weight box are helpful as well. My grandfather did all his plowing with their '42 Farmall A until they got their dozer, and here in Northern NY the snow is measured in feet (and occasionally yards). Provided you use good technique and don't expect to clear the entire driveway at once, the A is an excellent little plowing tractor.
Post A Followup
: Re: Re: can a farmall A push snow
