Re: Professional Tinkering 6 to 12 volt
Posted by Dan on January 19, 2004 at 10:21:03 from (12.160.160.64):
In Reply to: Professional Tinkering 6 to 12 volt posted by Kevin Westling on January 19, 2004 at 07:27:49:
If you go by the wiring diagram for the conversion done by Bob M you can't go wrong. The light from the # one terminal is as mentioned below, like a diode to keep the system from back feeding when yo try to shut it off. Without it you can't shut off the engine. You can also use a diode or resister in the line, I used a resister on mine. The amp meter won't care what voltage it is unless it is illuminated and that will take a 12 volt bulb. Depending upon the size alternator though you may want a higher reading one. As far as the coil, there is a way to check resistance on it, if you search archives on this site you should be able to find it. If it was converted to 12 volt with internal resister you willnot need the ballist resister. Ballast resister is the cheap way to go, much cheaper than a new coil. Not sure if you can build up starter contact or not. If you get it hot enough to add metal you may melt somethign inside. I had mine converted to a bolt and used a solenoid and starter button instead of the lever. Worked for me but I'm not trying to stay original. If you take it to a starter rebuild place they can put a new contact lug on. In mine the guy changed the windings to 12 volt. Guys will say that the 6 volt is adequate and that is true if everything is right on it. I like the 12 volt conversion on my SMTA and JD430. I have had no problems with either but here again they are users, not showers.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
