Re: Re: New 12V coil, coil says use with resistor
Posted by Hugh MacKay on January 20, 2004 at 18:41:02 from (209.226.106.37):
In Reply to: Re: New 12V coil, coil says use with resistor posted by Nebraska Cowman on January 20, 2004 at 17:23:52:
Cowman: Interesting, my Farmall 130 has a coil with lettering right on the side 12 volt coil, no external resistor required. The coil came from CaseIH here in Canada. I made note of what was written on the coil this afternoon as I was installing a set of points.
Post A Followup
: Re: Re: Re: New 12V coil, coil says use with resistor
