Re: Re: Re: New 12V coil, coil says use with resis
Posted by Greasy John on January 20, 2004 at 19:49:20 from (208.35.181.168):
In Reply to: Re: Re: New 12V coil, coil says use with resistor posted by Hugh MacKay on January 20, 2004 at 18:41:02:
Hugh I think you will find that "no resistor needed" means its already built inside with the windings. John
Post A Followup
: Re: Re: Re: Re: New 12V coil, coil says use with resis
