Re: New 12V coil, coil says use with resistor
Posted by Alont on January 20, 2004 at 20:04:59 from (209.71.219.207):
In Reply to: New 12V coil, coil says use with resistor posted by Bill in Orono, MN on January 20, 2004 at 17:15:00:
Hi Bill
older style 12volt coils and 6 volt coils were manufactured to run on 6 or 12 volts with the primary side coil wound to withstand the constant voltage for which it was designed, I used to have cars and motorcyles with these fitted.
When the engine is being cranked a 12 volt system battery will drop to about 9 volts hence the output at the coil secondary(the plugs) would be correspondingly lower during the cranking.
To improve this the manufacturers introduced a coil which was wound with a primary designed to run on about 9 volts.
A resistor was introduced in series(in line) with the coil which dropped the 12volts down to 9 volts at the coil during normal running.A relay operated during the cranking stage to bypass the resistor and provide the full battery voltage to the coil-which would have dropped to about 9 volts whilst cranking.This is the coil,I think, you were offered by NAPA. Hope this helps a little.
Post A Followup
: Re: Re: New 12V coil, coil says use with resistor
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
