Re: Weight of Farmall A?
Posted by Haas on January 21, 2004 at 05:46:51 from (12.65.30.160):
In Reply to: Weight of Farmall A? posted by Larry Kastens on January 20, 2004 at 18:56:37:
Fay's data book says 1870 lbs. I suppose that is stripped without optional equipment. rear wheel weights are 145 lbs each, front wheel weights are 45 lbs each. fluid in the tires will add another 200 plus lbs per tire depending on the tire size.
Post A Followup
: Re: Re: Weight of Farmall A?
