Re: Oil/Grease seal for Farmall A
Posted by Haas on January 21, 2004 at 12:51:22 from (12.65.50.178):
In Reply to: Oil/Grease seal for Farmall A posted by Tom Lehman on January 21, 2004 at 07:46:45:
The differential seal is National number 410060 SSR, or IH number 288864 R93. While you are in there, might as well replace the final drive seal too. That will require removal of the brake drum, which is not a hard job. It is National number 410083 or IH number 71597 C91. These are the latest IH numbers, as I just replaced these on a 1948 Shop mule, which is the same as the Super A. I think these seals are the same for the A through 140. I also suggest you replace the gasket on the retainer cover for the pinion gear/shaft. That gasket is IH 1342398 C1. If you replace the final drive seal, easiest to remove the pinion shaft/gear and bearing, which requires removing the retainer/cover over the end of the shaft and likely after 50 plus years, the gasket is shot.
Post A Followup
: Re: Re: Oil/Grease seal for Farmall A
