Re: 560 ta
Posted by RB on January 22, 2004 at 11:15:27 from (64.136.27.226):
In Reply to: 560 ta posted by ryan on January 22, 2004 at 10:28:47:
Yes, the TA clutch is probably stuck agsinst the flywheel. Remove the 4 bolt cover and first check the operation of the linkage, if you can see that the pressure plate is releasing you can use some WD40 spraying the disc and the spline. Also I've seen the pins come out of the pressure plate fingers. Good luck!
Post A Followup
: Re: Re: 560 ta
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
