F-30 wrist pins/piston pins
Posted by okla/kans Bill on January 22, 2004 at 19:04:48 from (209.240.205.63):
I had heard from some of you that you thought the knocking in my engine was from worn piston pins/wrist pins. I was looking in my parts book and I see that there are bronze piston pin bushings. Do you think that these would wear down before the pins or not. Thanks for the help. And also, did farmall make a lift that allowed you to use the pto also. Or was it to where, if you used the pto u had to take the power lift off, and if you used the power lift, you couldnt use the pto
Post A Followup
: Re: F-30 wrist pins/piston pins
