Re: F-30 wrist pins/piston pins
Posted by F-man on January 24, 2004 at 07:30:54 from (209.41.235.179):
In Reply to: F-30 wrist pins/piston pins posted by okla/kans Bill on January 22, 2004 at 19:04:48:
The pin bushings will most likely wear faster than the pin under normal conditions. Remember that the new bushings will need sized to fit the pin so a little pin wear can be compensated for.
Have you checked the rod bearings? These will wear faster than the wristpins and cause some knocking if they are out of adjustment. Another thing to check is the main crank bearings. An easy check for the front is to squeeze the fan belt and see if the crankshaft moves up and down. This condition makes a rumble/knocking sound as well.
I do not think that there was a lift available so that you could use the pto at the same time.
Post A Followup
: Re: Re: F-30 wrist pins/piston pins
