Re: ring gear removal
Posted by Hugh MacKay on January 23, 2004 at 05:49:11 from (209.226.106.167):
In Reply to: ring gear removal posted by RT (SE TX) on January 22, 2004 at 10:09:42:
RT: In removing a ring gear you are going to reuse, never get it red hot anywhere. As mentioned on many posts you can heat them in the oven for installation. All you need do is uniformly go around the ring with your torch, keeping the direct flame away from the actual flywheel as much as possible. You don't need to get the ring very warm until it will come loose. You can then just pull it off with a pair of welding gloves on turn it and put it right back save on the second heating. I find it very convenient to have a second person on hand. One guy can do the torch work, while the other guy is ready to remove ring. Torch guy can then quickly brush any crud from flywheel or ring. Then quickly back on, and torch guy can imediately return to torch just in case you lost too much from cooling. Before starting clean any rust or dirt away from portion of flywheel ring has to slip over.
Post A Followup
: Re: Re: ring gear removal
