Re: Farmall 230 clutch problems
Posted by bill b va on January 24, 2004 at 06:50:47 from (209.240.205.63):
In Reply to: Farmall 230 clutch problems posted by Hugh MacKay on January 24, 2004 at 03:51:30:
when the clutch is in and the transmission is in neutral the input shaft will turn with throw out bearing/pressure plate as a unit and not make noise when there is a problem ,there for it think you have a pressure plate problem . probably release fingers /disc.
Post A Followup
: Re: Re: Farmall 230 clutch problems
