Re: smta ppa bolts
Posted by JB on January 24, 2004 at 17:05:57 from (24.157.143.220):
In Reply to: smta ppa bolts posted by paul on January 24, 2004 at 16:37:10:
Hi, I have used a long flat screw driver in the starter hole. If the starter bolts are horizontilly across from each other I start the bolts in a few turns and the using a wrench lay it on top of the bolts and use this as a pry piont for the long screw driver.
MAKE SURE IGINITION IS OFF.
Good luck
JB
Post A Followup
: Re: Re: smta ppa bolts
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
