Re: Cracked Block on A/B/C etc. Farmalls?
Posted by gene b on January 24, 2004 at 17:50:17 from (67.1.109.37):
In Reply to: Cracked Block on A/B/C etc. Farmalls? posted by Al on January 24, 2004 at 14:24:10:
I have two mower tractors both Bs and they both have the famous crack behind the carb. I ground the surface down so toget rid of rust ect then applied a good coating of a good rubber cement the one has been running two yrs and the other one three with no problems and do not expect any. Would be worth a try can always change blocks later.
Post A Followup
: Re: Re: Cracked Block on A/B/C etc. Farmalls?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
