Re: Will Farmall C Implements Work on H
Posted by Jim in michigan on January 25, 2004 at 21:24:42 from (12.34.44.19):
In Reply to: Will Farmall C Implements Work on H posted by Scotty on January 25, 2004 at 20:33:24:
The loader should work, may need a lil modifying here and there,, dont think the mower will as the lift is different on the H and C.. buy the H and fix it, then you have both,,,Jim
Post A Followup
: Re: Re: Will Farmall C Implements Work on H
