Farmall Tractors Discussion Board
Re: O-12,W-12,F-12 Kerosene Fuel Lines.
Posted by Paul Fox on October 13, 1999 at 03:57:09 from (204.176.212.3):
In Reply to: O-12,W-12,F-12 Kerosene Fuel Lines. posted by Redfan on October 13, 1999 at 02:06:13:
Redfan, I saw your earlier post. I KNOW I've seen a picture of the layout on a O or W-12 somewhere, and I'm darned if I can find it anywhere! I'll keep looking, but in the meantime, my kero-burner F14 is plumbed like this:
One line from main (kero) fuel tank via shut off to inlet of fuel pump.
One line from outlet of fuel pump to bottom of tee on top front of kero tank under hood sheet.
One line from front of tee to another tee about halfway between Kero tank and hood tank.
Other side of this tee goes to hood tank via shutoff.
Bottom of tee to inlet of carb.
I'll look again for that picture, scan it and post it if I find it.
Post a Followup
: Re: Re: O-12,W-12,F-12 Kerosene Fuel Lines.
