Re: Re: Re: Live Power on Farmall M
Posted by Farmall_Nut of Kentucky on January 28, 2004 at 19:44:28 from (65.240.57.166):
In Reply to: Re: Re: Live Power on Farmall M posted by Bart on January 28, 2004 at 16:47:55:
Bart
You can use your belly pump resivoir for the belly pump as well as the live hyd with no problem. Drill the bottom plug to accept a 3/4" pipe for the suction to the live pump. Install a tee in the dipstick tube for the return line. This way you can use both hydraulic systems with only one tank.
Post A Followup
: Re: Re: Re: Re: Live Power on Farmall M
