Re: rear end noise on 706
Posted by Larry B on January 29, 2004 at 06:33:00 from (216.240.78.37):
In Reply to: rear end noise on 706 posted by casey on January 28, 2004 at 19:17:25:
Does the tractor set outdoors? Sounds like the brakes. The out side bearing would be poping when it turns. My 806 did the samething a few years back. Mine is inside in the winter but moisture still gets in the brakes from sweating and a little rust gets on them. Check after about 10-20 min. of use and see if the brake covers are warm. Could be the brakes set to tight
Post A Followup
: Re: Re: rear end noise on 706
