What is HyTran fluid
Posted by novice on January 31, 2004 at 07:43:15 from (193.130.33.3):
I have a IH 560D that I understand takes "HiTran" fluid in the transmission. Is this Automatic Transmission fluid or hydraulic oil or what? I am used to putting 90 wt oil in transmissions but understand here the hydraulic pump uses the same fluid. From the name am not sure what this is.--
Post A Followup
: Re: What is HyTran fluid
