Re: 606 trans
Posted by John on January 31, 2004 at 18:18:40 from (69.72.37.127):
In Reply to: 606 trans posted by Lary on January 31, 2004 at 16:03:42:
sounds like the shifter is wore. on ours if you take a light and look where the ball of the shifter rides in the slots you can usually take a screwdriver and slide the odd shift slot. if all of the slots are aligned there is a problem internally
Post A Followup
: Re: Re: 606 trans
