Re: Re: Re: Cub Charging Problem!!!
Posted by Bob on January 31, 2004 at 19:07:49 from (66.163.134.177):
In Reply to: Re: Re: Cub Charging Problem!!! posted by DaveB on January 31, 2004 at 17:29:13:
A working 12 Volt generator would give a reading of about 13.5 to 14.5 Volts across the battery with the engine running.
Your 12.5 Volt reading is just the battery voltage.
Post A Followup
: Re: Re: Re: Re: Cub Charging Problem!!!
