Re: 560D Injection Pump
Posted by Dave560 on February 02, 2004 at 17:43:28 from (208.42.12.35):
In Reply to: 560D Injection Pump posted by Bob Mills on February 01, 2004 at 21:19:32:
Bob-
There is another filter inside the pump. It is in the end of the pump body right below where the 90 elbow that the fuel supply line goes into on the end of the pump. If you unscrew the elbow and remove the larger nut below the elbow, the filter will come out of the housing. It is a brass screen type filter. Second thought here, is the fuel shut off lever all the way forward? Try pushing it forward manually, and see if that makes any difference. I've worked on these pumps where the fuel shut off lever is just a hair backwards toward the off position and the tractor behaves like you describe.
Post A Followup
: Re: Re: 560D Injection Pump
