Re: Will w-30 engine fit t-20 crawler?
Posted by F-Dean on February 02, 2004 at 20:19:51 from (12.74.46.159):
In Reply to: Will w-30 engine fit t-20 crawler? posted by J.R. on February 02, 2004 at 15:39:46:
I believe the crawler has a 10-20 engine which is the same as a W-30 engine without a water pump. Depending on the problems with the T-20 engine, you may be able to use the W-30 block and head without the water pump. Compare the head gaskets carefully to determine the differences.
Post A Followup
: Re: Re: Will w-30 engine fit t-20 crawler?
