Farmall Tractors Discussion Board
Re: Coil too hot!
Posted by RED Blooded on October 14, 1999 at 13:41:23 from (206.74.34.118):
In Reply to: Coil too hot! posted by Mike Dement on October 13, 1999 at 17:12:42:
Did you put the resistor from the battery/switch to the coil or from the coil to the distributor.It should be from the switch to the coil.You can also get a coil with a "built in" resistor and dont have to do any extra wiring.
Post a Followup
: Re: Re: Coil too hot!
