Re: Will w-30 engine fit t-20 crawler?
Posted by Mike Androvich on February 03, 2004 at 14:49:39 from (24.51.73.126):
In Reply to: Will w-30 engine fit t-20 crawler? posted by J.R. on February 02, 2004 at 15:39:46:
J.R., A W-30 engine will not fit in a T-20. The T-20 used an engine very similar to a F-20, except the crawler engine had a fuel pump and a water pump. Many T-20s have been converted over the years, but I can say with certainty that a W-30 engine is not the same. I have three T-20s myself. The block in the crawler does not use the tractor bell housing, but mounts with an adapter plate right to the frame. Will not work!!!
Post A Followup
: Re: Re: Will w-30 engine fit t-20 crawler?
