Re: MD compression
Posted by Farmaller on February 03, 2004 at 18:26:34 from (152.163.252.227):
In Reply to: MD compression posted by Ray on February 03, 2004 at 15:06:25:
It should start on gas fine , willmaybe miss alittle bit on #3. First make sure compression lever is opening the starting valves. You can check that by taking valve cover off. Have you checked for fire at the sparkplugs? Next check bottom of carburater to see if it,s getting gas. And what do you mean by acts like it,s out of time? And how did you get the motor unstuck?
Post A Followup
: Re: Re: MD compression
