Re: How do I set gap on my cub
Posted by Peabody on February 03, 2004 at 18:31:50 from (205.188.209.82):
In Reply to: How do I set gap on my cub posted by billy smith on February 03, 2004 at 18:13:15:
Billy,
The gap should be set at the HIGH side of the cam (what I assume your are calling the arbiture). That means on one of the four corners, not the flat side. That is probably your problem. Otherwise, I would suspect timing. But I would re-gap at "high cam" right now, and try that out. If that doesn't work, be sure to check back here. Good luck and don't give up! Glad to have you on this board!
Post A Followup
: Re: Re: How do I set gap on my cub
