Farmall Tractors Discussion Board
Front or rear blade for snow?
Posted by Mainbrace on October 14, 1999 at 15:23:37 from (216.40.143.201):
I have a front blade and a rear blade for my Farmall 140. I will be plowing a driveway of crushed limestone. Before I displace too much gravel, I would appreciate any tips that you might have.
Specifically, it seems that I have better control over the height of the rear blade. If I had an ashphalt driveway and didn't mind the front blade scraping now and then, the front blade seems like an advantage. However, I would like to still have some gravel in the driveway come spring.
What do you guys think?
Post a Followup
: Re: Front or rear blade for snow?
