Farmall Tractors Discussion Board
Re: Front or rear blade for snow?
Posted by Pete in PA on October 15, 1999 at 07:48:03 from (134.192.209.137):
In Reply to: Front or rear blade for snow? posted by Mainbrace on October 14, 1999 at 15:23:37:
I'm curious...
I've got a 140 also, and when you say front mount, you mean actually out front, or belly mount? Also, rear mount, how is it
hooked up? Do you have it on an aftermarket 3pt? Need a blade myself, so any insight you could offer would be helpful.
Pete
Post a Followup
: Re: Re: Front or rear blade for snow?
