Re: 460 Diesel starting problem.
Posted by RB on February 08, 2004 at 14:21:28 from (67.250.212.114):
In Reply to: 460 Diesel starting problem. posted by Daren Traugh on February 08, 2004 at 14:05:21:
If it won't start in summer, shortly after running, the injector pump head is worn or the timing is off. These engines are hard to start, all glow plugs must be working. If it runs good then it most likely is the injector pump.
Post A Followup
: Re: Re: 460 Diesel starting problem.
