Re: Re: Re: Re: Re: Re: 460 Diesel starting proble
Posted by Redman on February 09, 2004 at 12:43:13 from (66.44.173.126):
In Reply to: Re: Re: Re: Re: Re: 460 Diesel starting problem. posted by Hugh MacKay on February 09, 2004 at 02:33:03:
not all trucks run on series,if they do i have yet to see one that has more than a 24 volt system.4 batterys in a 24 volt set-up at 12 volts per battery means they need the cca to spin the engine over.i understood what he said,if you reread your post you will too.if you have 2 12 volts hooked together paralell you add the cca of both batteries together,if you hook 2 6 volts in series the cca remains the same but the volt output doubles.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: 460 Diesel starting proble
