Farmall Tractors Discussion Board
too many bearings!
Posted by Jon with an H on October 15, 1999 at 07:29:37 from (207.239.152.110):
I pulled the front hubs off the H to check the bearings. I had a clicking noise when the wheel was spinning. What I found was a mess. The original owner had a bering failure and had replaced it without removing the old peices wich were up inside the casting. My front hubs are cast and have a cavity inside. I pulled out loose bearings and chunks of race that had been smoothed off from bouncing around inside there for years! The inner bearing was loose because the axle has been worn down. It has been suggested that I have it machined and bushinged, but I would like to replace it. I have been told, and the parts manual seems to support it, that the front axle and lower bolster are one peice. But! There is a large rivet passing through the lower bolster and axle as if it holds the axle inplace and at the correct angle. So what do you all think, has anyone ever replaced an axle? Was it pressed in at the factory never to be removed again? I am prepared to replace the lower bolster, but also curious why it was made that way.
sorry, looks like I went on for a while.
Jon
Post a Followup
: Re: too many bearings!
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
