H Starting Problems
Posted by Randy on February 09, 2004 at 17:58:24 from (24.91.32.192):
I can't start my H and I don't think it is because of the cold weather. My battery is no good and up until a month ago I was using the hand crank to start it(magneto). When cold if I half choke the carburetor it will start but then bog down, as if flooding. By the time I run around to open the choke the engine has stopped. If I crank again the engine doesn't even try. It has to sit awhile, several hours. There is some gas leakage from the bottom of the carburetor. Any advice?
Post A Followup
: Re: H Starting Problems
