Re: Very Early Farmall M on 36 rubber
Posted by Paul in Mich on February 11, 2004 at 09:45:02 from (68.188.227.110):
In Reply to: Very Early Farmall M on 36 rubber posted by Lee Sackett on February 11, 2004 at 06:48:07:
Lee, while I seldom if any ever respond to a thread inquiring as to the worth of a tractor, I will make an exception this time. I would say that if the tractor runs well, and the sheet metal is good as you state, then I don't think you can go wrong with the price you indicated. YOu may try to negotiate downward more and see just what the present owner will accept, but asside from having to scrounge for 36" rims, if they are bad, you have a valuable tractor when restored.
Post A Followup
: Re: Re: Very Early Farmall M on 36 rubber
