Re: mystery engine
Posted by lee on February 11, 2004 at 22:26:15 from (24.24.92.235):
In Reply to: mystery engine posted by derek carter on February 11, 2004 at 19:42:24:
I have that block in one of my tractors. There is a plate under the mag where you can bolt up a hydraulic pump. There is a missing bolt on the right side where the engine bolts to the clutch housing. I got the tractor with that block in it so I don't know what it came out of. I put an overbore kit in it many years ago. It was 3 inch bore when I tore it down and I can't recall if the kit was 3 1/8 or 3 1/4 bore. I am tending to think it was 3 1/4. Post the kit you finally find for that. Mine came with aluminum domed pistons. The motor runs very strong. You have to be careful you don't get in a situation where you have too much load and too much traction. It will get on the governor and pull the front end up in a big hurry.
Post A Followup
: Re: Re: mystery engine
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
