Re: M-live hydraulics
Posted by RB on February 12, 2004 at 09:18:41 from (65.128.72.47):
In Reply to: M-live hydraulics posted by Steve on February 12, 2004 at 08:30:34:
Yes a Super M pump will work, one may also have the manifold block that bolts to the pump which has pipe thread holes you can plumb from. I have a 1951 M equiped this way using the rear end for reservoir. If you use the rear end this way you will need to replace some of the seals due to the Hy-tran leaks, but that's no problem. Pto, front countershaft and possibly axle seals. More than likely they need replaced anyway.
Post A Followup
: Re: Re: M-live hydraulics
