Re: 424 In-place Flywheel Gear Teeth Reconditionin
Posted by Randy in NE on February 13, 2004 at 08:33:53 from (216.58.237.20):
In Reply to: 424 In-place Flywheel Gear Teeth Reconditioning posted by BlueLite on February 13, 2004 at 08:18:27:
I couple of weeks ago somebody else was asking the same question. It was discussed about filing the teeth square. The problem I see with this is that you are shaving more material off the teeth. Yes, you are making them look pretty but in the end the teeth are still worn down. I can see where this may cause more wear on both the ring gear and the starter drive gear. Just my opinion.
Post A Followup
: Re: Re: 424 In-place Flywheel Gear Teeth Reconditionin
