Re: 424 In-place Flywheel Gear Teeth Reconditionin
Posted by Nebraska Cowman on February 13, 2004 at 10:13:44 from (65.172.142.105):
In Reply to: 424 In-place Flywheel Gear Teeth Reconditioning posted by BlueLite on February 13, 2004 at 08:18:27:
No, you can't do that. the teeth are worn off like Rany said. grinding more off them won't make them better. the gear is a ring seperate from the flywheel. you may be able to turn it 180° or reverse it. But yes, you are going to have to split the tractor.
Post A Followup
: Re: Re: 424 In-place Flywheel Gear Teeth Reconditionin
