Re: Re: H 12v alternator?
Posted by Doug in OR on February 13, 2004 at 21:49:14 from (67.166.95.121):
In Reply to: Re: H 12v alternator? posted by Bob M on February 13, 2004 at 18:51:04:
Most alternators follow a similar wiring scheme. Below is a short list of the terminals, and what they mean. BAT: This is the main battery terminal. It is the same on all alternators. The Delco 10SI, the Delco 121/130 series, the Nippondenso alternators.. Hitachi.. etc. S: The sense terminal. This is pin 2 on the 10SI. Connect this either to your battery, or the alternator BAT stud. On the Delco 121/130 series alternators, this terminal will usually be under the rubber packing. You need not connect it on the 121/130 Delco - this alternator uses internal sensing. I break out this terminal and use it only when I am using two batteries and a battery isolator. I: The exciter (ignition) terminal. This is pin 1 on the 10SI. Connect it to your ignition switch. You may or may not need a diode, depending on the alternator. On the 10SI, you can use a diode or lamp configuration. L: The indicator lamp. You don't need to use this terminal. Attach a warning lamp here, as you would on a 10SI, if you wish. This is a quick and dirty run down of the various terminals. There's really not much difference between one alternator or the other. The 10SI is the most popular because of the price. I suspect that the Delco 121 or 130 alternators should be inexpensive too - they started using them in about '85, right after the discontinued the 10SI. I don't know the physical size of the 121, but it might be smaller than the 10SI. I know for certain that a Nippondenso for an old mid-80s Toyota will be smaller.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
