Re: belly mount weight bracket
Posted by ny bill o on February 15, 2004 at 13:07:37 from (66.24.251.60):
In Reply to: belly mount weight bracket posted by Tye on February 14, 2004 at 17:06:11:
i built one for my 560 out of 3x3x1/4" angle iron. i cut 2 pieces about a foot and 1/2 long for vertical pieces, blew hole in top with torch for 3/4" bolts into 560 frame. i used more of the same angle, just a couple inches narrower than the inside tire width, and welded the 3 pieces together. added a plate on each end of horizontal piece so weights can't slide off and hit tire. i've seen some that had an angle brace back to the tractor but mine doesn't have one. i tightened the bolts tight and it doesn't move. not fancy but it works. my digital camera is on the blink so i can't give you a picture.
Post A Followup
: Re: Re: belly mount weight bracket
