Re: Re: Re: 300 12 or 6 volt?
Posted by 26Red on February 16, 2004 at 10:54:10 from (170.92.1.104):
In Reply to: Re: Re: 300 12 or 6 volt? posted by Brian Schmidt on February 15, 2004 at 19:41:03:
Hy-tran is a little too thin- you'll be grinding gears trying to shift, because everything is still spinning. A heavy gear oil is the best.
Post A Followup
: Re: Re: Re: Re: 300 12 or 6 volt?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
